Any feedback on the whiteline ARB
josh1210
Post by josh1210 »
Just bought a Whiteline front ARB as I took the standard one off to avoid contact with the driveshaft. Anyone got one fitted and have anything to say about it? Does it remove all possibility of driveshaft contact?
SimonCorrigan
Re: Any feedback on the whiteline ARB
Post by SimonCorrigan »
fitted one yesterday. it was the adjustable one. rwf18z. a couple of things that we had to do on the one i had was bore the holes out that attah the droplinks to as they had been stamped rather than drilled and also paint made it difficult to get the bolts through. also there are some collars on either side of the arb these were 10mm to closer together than the original so they needed to be `persuaded' to move. other than that it wasn't too difficult as we had the subframe off the car and made access fairly easy.
