Hi Guys, Just a quick question...
Im about to change my front lights and i was wondering, is it possible to remove the radiator grille and headlight surround
all as one piece. Instead of removing the radiator first then the headlight surround.
Any help apprieciated
Mk4 (6n) radiator grill
tomo223344
Re: Mk4 (6n) radiator grill
Remove the grille then surround. Take off the indicator lights off and then the main headlight.
JarnoVWPolo6N
No need to take off the headlights, just grill, and then indicators are enough to then pull out the surrounding
^^ Didn't realise what part you were actuallt trying to remove. If its the surrounding then follow Jarnos instructions.
