Does anyone know how to remove the indicator lens on the passenger side door mirror?
It's got quite a bit of water inside and I would like to try and seal it.
Has anyone had the same problem and fixed it?
Hopefully I won't have to remove the mirror glass because every time I touch one of those, they break!
Steve
Mirror Indicator removal?
Re: Mirror Indicator removal?
Anyone?
has anyone had to change the bulb?
After some internet searching, I found this for a Golf.
http://forums.vwvortex.com/zerothread?id=3819890
It's almost identical for the Polo so should help anyone needing to replace their indicator.
