I need the : GTI split rim refurb DIY guide
Hey,
Does anyone have a PDF of the GTI split rim refurb DIY Guide?? The thread has lost all it's pics & the link to the PDF doesn't work.
I fancy giving the refurb a go as I got a quote for £105 per wheel!!
Hedges_GTI
Re: I need the : GTI split rim refurb DIY guide
I also need this! just got some 16" BBS rx, on the same topic does anyone know where i can get the tripple square bit you need to split the wheels? or does any one they want to sell / lend me:)
kingsleysaywell
i need that key thing too please ?
If some kind person has this DIY guide, could you email it to [email protected] it will be much appreciated.
I will forward it on to the others who want it.
Cheers people
Cheers people
wheelmanwayne
its pretty easy tbh you will need a 8mm multispline torque bit with a good lever to undo the bolts,,
a lump hammer and a piece of wood to split the rims with no damage, put the wood on the backpad of the wheel then hit the wood with the hammer, it may take a few hits to free the center from the outer lips.
then get you polishing fingers out and be ready for some hard graft!
Don't like the sound of hard graft lol.
The wheels were refurbed a couple of days befor i bought the gti, but the lacquer on the lip came off within a couple of months - the centres seem ok.
So... i don't think I need to split the rims - i was gonna try & polish the lip without splitting them - Is this easy to do. Just Sand paper & polish needed??
I have no experience at all of doing any wheel refurbing polishing.
wheelmanwayne
ahhhh what i would do then is still split the wheel as its 10x easier to do the whole lip and you wont damage the centers in the process! the strip the laquer off which some nitromors or paint stripper rub down with 600 wet and dry in some hot soapy water, then go to 800 wet and dry and finally finish on 1200 wet and dry ( the wetter the better as they say). once you have done this the wheel will be ready to polish! get yourself one of these beautys http://www.machinemart.co.uk/shop/produ ... -polishing all you do then is rub the polish on the polishing mop and keep polishing till you see a good shine starting to appear! once you have the shine go over the rim with the cleaning mop and bling bling hey presto
emma_88
- Drives: 6N2 Polo GTi & 9N3 Polo GTi
I have the PDF version on my laptop somewhere, I'll email you it when I find it.
Don't lacquer the rims after you've polished them - The same will happen again! Just make sure you seal them with some poorboys wheel sealant. Will do the trick. Also, use scotchbrite and some Autosol to polish them up with, works a treat.
Cheers for that.
I'm on the look out for some cheap temporary wheels on ebay, cos I need the car for work, then I can giv the refurb a go & just take my time with it.
Will keep u posted with how I get on!
emma_88
Sent!m@t_gti wrote:Cheers emma_88 - can you send it to [email protected] if you do manage to find it.
Matt
wheelmanwayne
emma can you send that my way too please i wana see if its any different to the way i did mine!
[email protected]
thank you
[email protected]
thank you
emma_88
And again.. Sent!wheelmanwayne wrote:emma can you send that my way too please i wana see if its any different to the way i did mine!
[email protected]
thank you
emma could you please send it to [email protected] too please ?
Hey guys!
Just picked up some crusty wheels too, could someone pass on the pdf, or re-post the guide? My email is [email protected].
Thanks,
Tom.
Thanks,
Tom.
