possible water leak
g__humm
possible water leak
Post by g__humm »
just had car serviced not long ago and it seems that the water has gone down a bit is this normal for polos to do so or is it leaking
chewy
Re: possible water leak
Post by chewy »
Top it up again, if it goes down then you know it has a leak. If not it just had some air trapped
RITCHAT
Post by RITCHAT »
Could be a number of things here from something simple like the bleed valve for the air to be released not being closed correctly to the headgasket being knackered or as chewy stated it could have been an air lock that has rectified its self. Do you have a lot of white smoke from your exhaust? The car will use a little water over time but not so much that you have to keep filling it up. Take it to vw and they will do a pressure test and this will tell you what the problem is. Good Luck.
g__humm
Post by g__humm »
i know what a head gasget issue is lol used to have a rover no offence lol no it just black when the foot goes down lol
RITCHAT
Post by RITCHAT »
Good gald that has been ruled out 8) and pleased to see you have come to your senses and bought VW :lol:
g__humm
Post by g__humm »
it was a metro and was fun to drive but that bout it lol
