Can you put a 6n2 interior into a 6n? I know you can use the dash but that requires a lot of work.
Can the front and rear seats, including the door cards be stripped from a 6n2 and put into a 6n?
Seats should be a simple enough swap, all you'd need to do (if anything) is swap subframes over. Doorcards is a tricky one. If you can adapt the doorhandles and any electric bits (mirrors) then it would just be a case of seeing if the doors are the same shape.
