Sidelight Change
- the_mini_mole
Sidelight Change
Hi guys, I have a sidelight gone in my Polo, and have looked in the handbook about changing it but it says take it to a VW dealer- I had a look in the engine bay at the back of the unit but I couldn't see any way of removing the bulb, but Shirley there must be a much easier (cheaper) way than taking it to a dealership?
Thanks in advance
James
Thanks in advance
James
Re: Sidelight Change
Have a look in the how to guides section of the forum, there are a couple of guides in there
- the_mini_mole
Doh! Totally missed that. Looks good, bookmarked, lol.
Also I was thinking of changing to white sidelights- are these any good? http://www.ultraleds.co.uk/501194t10-si ... -1614.html
If not are there any recommendations that are good?
From personal experience, i wouldnt replace with the led sidelights as every set i have had fail after just a few months and its a pain to change them. Some phillips blue sidelights would be a good bet as they shine a nice white
- the_mini_mole
Something along these lines?
- chrischap2003
what a fanny on this is by the way lads haha...If you change for LED's then buy GOOD QUALITY ones!
Personally i wouldnt advise you change them unless neccesary
- the_mini_mole
They do need changing- one is gone and I normally always have my sidelights on (easier to see dials and easier to be seen)
I agree it is abit of a bastard to change these, but as you say if ones blown it's necessary.I would reccomend these LED's,i have them and am aware a few other members on here do too and rate them.If you buy cheap s**t ones then expect them to blow they will be made poorly, same with all cheap electronic goods.
http://www.ultraleds.co.uk/ultimate-501 ... -1677.html
Brad
Brad
Have you got any pics of these working matey on your motor-would be interested to see what they look like with just sidelights on ....and then headlights too.Bradley wrote:I agree it is abit of a bastard to change these, but as you say if ones blown it's necessary.I would reccomend these LED's,i have them and am aware a few other members on here do too and rate them.If you buy cheap **** ones then expect them to blow they will be made poorly, same with all cheap electronic goods.
Brad
- chrischap2003
Those are the ones ive recently purchased also. I made the mistake of buying cheap ones first DOH! haha
These just look and feel a ton better in quality, and hopefully they will last
pocketrocket786 wrote:Have you got any pics of these working matey on your motor-would be interested to see what they look like with just sidelights on ....and then headlights too.Bradley wrote:I agree it is abit of a bastard to change these, but as you say if ones blown it's necessary.I would reccomend these LED's,i have them and am aware a few other members on here do too and rate them.If you buy cheap **** ones then expect them to blow they will be made poorly, same with all cheap electronic goods.
Brad
I'll try and get some up at the weekend,im quite lazy though sometimes so no promises.
- Tim_GTi
- Post Whore
Get the ones Brad posted and be done!
I've had them for two years now, and still work great.
