Electric Window Switch
BobbyG
Post by BobbyG »
Hi All,
I'm having trouble with my drivers side electric window switch (i.e. it doesn't work!).
The passenger window opens fine via it's own switch, however when using the drivers side, all I get is a "click" noise, but no movement, whilst the door lock/unlock master switch works fine.
Just to recap, neither windows can be operated from the drivers sidem, but the lock/unlock function is fine.
Anyone have an idea if I'm looking at a new switch or a new motor etc?
Taverymuch
neilGTI
Re: Electric Window Switch
Post by neilGTI »
I am having similar problem at the moment, try turning off the heated rear screen and see if the passenger window opens from the drivers side.
Do the windows open from holding the key in the lock ??
BobbyG
Post by BobbyG »
Having the heated rear screen on has no impact, I'll try the key in the lock later! (didn't know it did this??!!)
acid drop
Post by acid drop »
swop the switches over, that way you can eliminate switch faults
BobbyG
Post by BobbyG »
I've already tried lifting the switch out, but struggled. Any tips?
neilGTI
Post by neilGTI »
stick a blunt knife under the switch panel from behind the handle, pushing towards the boot and then prize up with your fingers, thats how i do mine anyway
BobbyG
Post by BobbyG »
OK so tonight I've discovered that the windows DO function using the "key in lock" method.
I removed and dismantled all of the switches, gave them a good clean etc, however the problem remains that the window switches merely produce a clicking sound, but no movement. The central locking switch is fine.
I'm obviously ruling out the motor since the windows can be operated by the key.
Can I rule out faulty switches due to the audible click?
Am I more than likely looking at an issue with the wiring loom? :?
Cheers,
neilGTI
Post by neilGTI »
Check the wiring between the door and the chassis, i found a broken cable in mine last night, i re-jointed the cable now it works perfectly again :)
BobbyG
Post by BobbyG »
I've checked the wiring btween door & chassis and all seems fine.....
SO EITHER
There's a wiring problem behind the door card.
OR
There's something wrong with the switches.
:roll:
neilGTI
Post by neilGTI »
The switches are well know for getting water in them when you have your window open in the rain.
Try swapping the switches over to see if it is definitely the switch or not.
