will fit a w reg polo gti?
Please respond if you know,
Thanks,
Dan
What wheel hub's
- Tim_GTi
- Post Whore
Re: What wheel hub's
Bit of a weird question.
I guess you mean what wheels fit on a GTi?
The stud pattern 4X100, centre bore is 57.1mm.
Generally stick to 15"s or 16"s. 17"s look crap, and not all 14"s clear the brakes.
Wheel width tends to be 6-8"s, and safe offsets site between ET10-45.
Of course the immediate above measurements depend on each other. IE a wide wheel won't fit if the ET is too low.
Sorry i clearly didnt explain myself very well.
I mean the actuall wheel hub itself where the wheel bolts on to. I need one for my 6n2 gti and wondered if i could use one off the ordinary polo or lupo?
Any ideas?
Any ideas?
Dont hold me to it... but doesnt the 6N and the 6N2 use the same front uprights and hubs? Im fairly sure they do..
In which case... go to any scrapyard.. find a polo... and get one!
i had a feeling this was the case, thanks.
