The installation of the Pc is practically plug and play, they way in which I completed the soldering of all the components is so that everything was very versatile in sense that the pc could be moved in and outdoors!
The kit comes with everything to put it in bar the screen. You can pic these up cheaply and I'll also point you in the right direction for one!
COMPUTER - £200
- Windows XP OS (cut down version of the windows, so it loads faster when ignition is switched on)
- 120GB 3.5" HDD.
- CPU P4 2.4 ghz Socket 478.
- 1GB DDR RAM.
- Built in GFX.Sound,LAN and Firewire.
- Slimline Laptop DVD + R/RW, CD+ R/RW.
- Road Runner Front End touch screen software pre-tuned to work with winamp!
- A heap of flash games, films and songs.
- (Can install Navigator in for you, all you would need is to buy a USB GPS receiver £4-5? on Ebay.
- Can also Install Office 08 completely free as well!
CarNetix CNX-P1900 V2 +19V/140W DC-DC Regulator + connector plugs : £90
- All it's 8 gage wiring including (in-line fuse holder).
- Ignition switches.
- Manual turn on switches.
- 15A miniature fuses.
- USB mini thumb Qwerty keyboard.
- USB mini mouse.
- USB mini hub (4 ports).
- Extra faceplate without CD bezel slot.
- Touch screen drivers
- USB Bluetooth Dongle.
- Can also throw in a 6N glove box, modded to accompany all the wiring if need be.
- Adapter to plug computer into your home.
http://video.google.co.uk/videoplay?doc ... &plindex=1
http://video.google.co.uk/videoplay?doc ... 5&hl=en-GB
