Door struggling to open
yosin
Post by yosin »
Just recently noticed my passenger door becoming harder to open :?
You have to pull so hard and back till it clicks open. :!:
Anyone noticed this kinda problem before?
Si_GTi
Moderator
Re: Door struggling to open
Post by Si_GTi »
Hmmmm. My driver's door has been more difficult recently, due to it becoming almost totally frozen shut in the recent cold snap (when it was -8, brrrr!). I need to remove the doorcard and check the door pull inside as I think I've pulled it out of alignment a bit! Could be worth checking your passenger door in the same way?
Also, just to check - is it the interior door pull or the exterior door handle we are talking about here? My interior door pull on the driver's door does what you describe as a consequence of my first point :?
yosin
Post by yosin »
yeah its my interior door pull of my drivers.
Hopefully its the cold snap.
Feels like it doesnt even want to open sometimes!
Trottagti
Post by Trottagti »
If your doors are slightly out of line then the locks will not work properly ther-for being hard to open n catching but it could be a simple fix like grease up the moving parts and locks as we all probably remove the grease cos it looks dirty ya know, try some lube!
yosin
Post by yosin »
hopefully its that simple, hopefully some KY will liven things up abit and make things open up! HA!
Trottagti
Post by Trottagti »
U make me sick lol, Na it should do the job mate its well worth a try! :wink:
