OUCH!
Dub_Dan
OUCH!
Post by Dub_Dan »
hub syncros went on gears 1 & 2 on my tdi just spent ££££ on a recon box from VW i wanted to know is blipping the gear changes bad on a tdi on the downsift?
david burton
Re: OUCH!
Post by david burton »
do you double clutch when you blip? Probably a crap idea if you don't. Still shouldn't wreck the synchro unless you're doing something very wrong.
Dub_Dan
Re: OUCH!
Post by Dub_Dan »
i cant understand i completely lost 1st gear dab on the accelerator when going into the lower gear coming of the clutch smoothly making the downshift smooth.
Dub_Dan
Re: OUCH!
Post by Dub_Dan »
and i never really go into first gear unless i have to stop the car
g__humm
Re: OUCH!
Post by g__humm »
cant think of a reason thought that a blip was meant to make ur box last longer as it dont jerk the gears with back lash in the teeth. because the engine is then doing the same speed as the gearbox, rather than the engine going slower causing a extra stress on the teeth
please tell me if im wrong
Dub_Dan
Re: OUCH!
Post by Dub_Dan »
guys this has cost me alot to fix im so upset as i planned for my votex to go on this month... a massive hole in the wallet.
zedzo
Re: OUCH!
Post by zedzo »
wats a blip :lol:
david burton
Re: OUCH!
If you don't double clutch your synchro still has to do all the hard work regardless of the blip.
To properly relieve the stress on your gearbox you need to shift into neutral with the clutch depressed, engage the clutch whilst in neutral, blip, and then engage the next gear with the clutch depressed. This removes the need for a synchro as the engine's speed matches the gearbox revolutions when you engage the clutch in neutral and blip.
david burton
Re: OUCH!
Dub_Dan
Re: OUCH!
Post by Dub_Dan »
thanks so i have definitely come to the conclusion this is not my fault and something from the previous owner!
Dub_Dan
Re: OUCH!
Post by Dub_Dan »
zedzo have you mapped your car with the 130 turbo yet?
zedzo
Re: OUCH!
Post by zedzo »
nah im too lazy yet :lol: plus im hapi with the power i have now, i dont no if im gna sell it in winter or keep it for another year so mappings on hold yet, :lol:
