I have been having problems with the tempature guage reading 90 then dropping down to 0 then up to 90 and so on.
Has anyone else had this problem? If so how did you fix it?
fitting a new thermostat?
Re: fitting a new thermostat?
Its not the thermostat. Its the Green 4 pin temperature sensor on the thermostat housing. Its about £20 quid and takes 5 mines to replace. Happens on alot of the polos...luckily theres a guide in the DIY section to show you how.
bradley1983
Cheers. I replaced the thermostat any way. Was only £8 from GSF. I will do the sensor today then.
