rear lights female pin connector??
Wooly_9n
Post by Wooly_9n »
So I've done the classic 9n3 rear lights on a 9n and sorta bodge the wiring job so need to do it properly. Basically the 9n3 wiring is different but I've bypassed this by putting in some bullet connectors. how ever one pin needs to have the female to connect to it but there isnt one in the wiring plug loom box?
There are 6 pins from the back of the rear light cluster which connect into a case/box which houses the female connectors for these pins. one is missing and i need to get one?
what are these female conectors called?
where can i get em from?
Anything to further my knowledge on this subject would be a major help.
plus if you think you maybe able to help but dont quite understand what I've just rambled on about please comment.
Cheers,
Wooly
chewy
Re: rear lights female pin connector??
Post by chewy »
You will find a guide in the downloadable file
http://www.mediafire.com/file/mngnmmygwyj/fwd9nmods.zip
Wooly_9n
Post by Wooly_9n »
cheers mate thanks for that :)
