yesWhos Adam? wrote:Are you running a 5 speed Yorks?yorks GT TDI wrote:great work
can you confirm what model the gearbox came out been looking into this i know the mk5 1.4 tsi gearbox looks like the one you have and also touran also do you have more details on the mods you had to do to get it to fit
also you did no other mods ie swap the input shafts or bell housings
thanks
Black Polo GTI 6 Speed. 390 BHP Build
yorks GT TDI
- Sponsor
Re: Black Polo GTI 6 Speed now fitted pics Pg5
Haven't seen a 1.4 tsi gearbox but have seen a Lupo 6 speed which looks similar but to small. As the tsi is a small block i would assume it is the same box as the lupo.yorks GT TDI wrote:great work
thanks
The o2s box i used was from an Audi A3 FSI (non turbo) you can also use the Touran and some others.
I have a document with all the codes and ratios if you want just send me your email address.
How much did you pay for you mounts from vibra technics?
If you are gong to do this i will have a chat to you about all the bits i had to over come if you want.
yorks GT TDI
- Sponsor
will have to check my bills for the mounts think one was 100 and the other aorund 150 but i carnt remember9N3 Turbo wrote:Haven't seen a 1.4 tsi gearbox but have seen a Lupo 6 speed which looks similar but to small. As the tsi is a small block i would assume it is the same box as the lupo.yorks GT TDI wrote:great work
thanks
i will be going six speed if i can do it this way the great will save me the hassle of getting a gear set
[email protected]
any info on what needs moding and pics would be great
yorks GT TDI
- Sponsor
got the email but the file is unable to down load
Resent to youyorks GT TDI wrote:got the email but the file is unable to down load
Awesome mate, does it drive much different? Drive shafts just bolt straight up or did you have to swap flanges etc?
Hi Callum thanks for the comment.Callum wrote:Awesome mate, does it drive much different? Drive shafts just bolt straight up or did you have to swap flanges etc?
The box I went for was a petrol model which the 6th gear is very very similar to the GTI gearbox 5th (3000 rpm = 70mph, 4000 = just under 100 mph).
What this means is you get amazing in gear acceleration which i am very happy with.
I haven't tested this against another GTi but will be testing against my mates 200bhp mk4 golf which he only verrrrrrry slightly had an edge over my GTI (std 150 map) so will let you know how that goes.
As for drive shafts they just bolted straight up and gearbox bolts straight up to our engine.
Done a few little bits over the last month or so
Fitted a Forge TIP
PD 160 air box intake upgrade
plus a little extra
Before
After
Only 2x torque screws holing it in
Fitted a Forge TIP
plus a little extra
Before
After
Re: Black Polo GTI 6 Speed. Air intake upgrade with pics pag
Did you have to change the clutch, or did the old one fit with the 6 speed gearbox?
Same old clutchvlad_pvs wrote:Did you have to change the clutch, or did the old one fit with the 6 speed gearbox?
Thanks for the reply
I was confused because when I bought my clutch it was "only for 5 speed gearbox". So I will be looking for a 6 speed gearbox now
No problem good luck.vlad_pvs wrote:Thanks for the replyI was confused because when I bought my clutch it was "only for 5 speed gearbox". So I will be looking for a 6 speed gearbox now
Let me know once you have the bits and i will let you know of a few pointers
The intake looks good, I didnt realise the difference in size was so big. You wouldnt have the part numbers for the 2 parts would you? Is it a VW or Seat part?
Cheers Josh
Cheers Josh
Here you go fella.JoshGTI wrote:The intake looks good, I didnt realise the difference in size was so big. You wouldnt have the part numbers for the 2 parts would you? Is it a VW or Seat part?
Cheers Josh
6LL129621 adapter
6LL129618 hose
These are Seat parts so will need to be ordered from them.
Or you can get it from Jabba Sport delivered to your door.
