Wish I had a black car now
What kinda wheels look good on a 9N?
carmadaaron
carmadaaron
carmadaaron
This wheels are too big in my opinion. Reasons:
- The cost of the tyres;
- The cost of the wheels;
- Totally absence of comfort (attention to the conditions of the road);
- Problems with the law? (in Portugal the larger size admitted in this car it´s 17");
- Bigger risk of aquaplanning;
- Non suspension weight (18" wheels weight a lot). OZ Superllegera it´s a better choice, for example;
- Higher Consumption of fuel;
- Less overall performance;
Go for (OZ Superleggera
) 17 inches wheels!
carmadaaron
thankyou for your input.POLO9NTDI wrote:This wheels are too big in my opinion. Reasons:
Go for (OZ Superleggera) 17 inches wheels!
the cost of my wheels and tyres i have been quoted £1040.
is there a law in th UK for too big wheels?
mines a 1.2 3cyl so its not really for speed
i prefer 5 spokes as theyre easier to clean than multispokes
im going for looks for this car
as for fuel consumption, does it really make a great impact?
Aaron
Hi carmadaaron,
The impact of fuel consumption it´s expressive from 14"/15" to 18", but from 17" to 18" it will be also noticeable.
The decrease of "overall performance" it will be noticeable in reprises (for me it´s more important than top speed).
In my opinion you only have two advantages:
- aesthetics;
- More grip in curves.
But if you go ahead with this two options choose the RS4 Replicas (it´s my personal opinion)
Cheers and sorry for my poor english
- aesthetics;
Nah...
fuel-consumption won't increase when a wheel gets higher. When a wheel gets wider, that's when fuel-consumption will rise. The aerodynamics will be a little worse. But roll-resistance of a tire will be the biggie. A sport-tire is made for grip and does increase roll-resistance quite a lot (compared to a normal Eco-tire). Also there is more rubber in contact with the road because you want bad-ass wide wheels
Bigger tires do have some pro's and against's. Grip is a big improvement. Not only for cornering, don't forget the big difference in braking-distance when an emergency-stop is required. The difference can be as much as 8 meters from 100 km/h (66 mph) to zero between a good tire and a bad tire.
Hi Joy,
Don´t forget one thing, usually higher wheels requires wider tires if you want to keep the same total diameter of the wheel (it prevents errors in the speed meter).
For example:
- 195/50R15
- 205/45R16
- 215/40R17
- 225/35R18
So the fuel consumption will increase...
You can also get good tires in 16"/17" (Good Year F1 GS-D3, Bridgestone S-03...) and we are talk about 1.2 3 cylinder car...
For example:
- 195/50R15
- 205/45R16
- 215/40R17
- 225/35R18
carmadaaron
@POLO9NTDI,
not true. A tire doesn't have to get wider each inch a wheel gets higher.
For example, a car is delivered on stock wheels 155/65R14. Now the buyer doesn't like the wheel and wants 15 inch wheels with the same tire-width (155). So he has to fit 155/60R15.
The number 155 stands for the width of the tire in mm's.
The number 65 or 60 stands for the height of the tire. 65 means the side of the tire is 65 % of the width of the tire. So 65% of 155 mm.
As long as you keep the roll-distance of the wheels within 2% of the original setup ABS and your speedo won't get upset.
Greetz Joy
Greetz Joy
Joy I respect your opinion.
But for me the story it´s different... if you want to improve the setup of the car - concept "plus one" or "plus two" - you have to get wider and lower when a wheel gets higher.
On the other hand if you have 185/55R14 and you go up to 15", in this case you have to use 195/50R15 because the wheel is wider (usually 7 against 6).
Usually the wheels are:
5,5x13''
6x14''
7x15''
7,5x16''
8x17''
Cheers and always friends
5,5x13''
6x14''
7x15''
7,5x16''
8x17''
carmadaaron
carmadaaron
