greased the two runners, and a spring like thing in the middle, but wernt sure where else to grease.
didnt know where the regulator is?
the window goes down fine, but when u try and go back up, it will either not work, or go up a bit, then bounce back.
it will go fully up if u pull the window with ur hand and press the button at the same time.
what should i be doing to sort this?
its getting hott noww
