Which BMC airfilter do i need for 2000 gti 1.6 16v?
Hi people, ive had a look on websites but there are no bmc filters which are specifically for a polo gti 1.6 16v, i want to fit one because i know it can be done, just dont know which one can fit or is similar enough to fit/ work efficiently for the car. Thanks.
- 6N2 GTI 00
- Location: North Wales, Denbighshire - Drives 255bhp EP3 Type R!
Re: Which BMC airfilter do i need for 2000 gti 1.6 16v?
The BMC CDA unit you will need for your GTI has the following part number - BMC CDA70-130
http://www.kamracing.co.uk/index.php/vo ... v-gti.html
Ben,
Ben,
cheers man appretiate that
- 6N2 GTI 00
No worries mateleon371 wrote:cheers man appretiate that
Kam racing is probably one of the best places to get it from because it comes with all the correct parts such as the breather filter, brackets, reducers, 90 degree silicon bend and the 70mm cold air feed.
