Clutch Replacement
neilw
Clutch Replacement
Post by neilw »
Its getting harder and harder for me to select gears now, mainly reverse, I get abit of a crunch. Is this a sign the my clutch is nearing the end of its life or just the cable? The cars done 93,000miles now and Ive not had it changed since I owned the car since 30,000 miles.
What is the likely cost to have it replaced at an indy?
MrP
Re: Clutch Replacement
Post by MrP »
About £200 - £300
£100 for the clutch and the rest for labour..
Make sure you get a good clutch like Sachs, Vaelo or LUK.
How stiff is your pedal? have you tried adjusting the clutch cable?
neilw
Post by neilw »
MrP wrote:About £200 - £300
Thats around the figure I had in my head for some reason. The indy I use, uses genuine parts, I will check the brand, but i guess it'll be one of the ones you mention.
The pedal doesn't seem to of got any stiffer. I've not adjusted the cable at all. I'll have a read up on how to do that.
MrP
Post by MrP »
Vaelo is OEM I think.
Literally on the top of your gearbox you'll see the cable, and a black nut style thing, it may be stiff, but you can rotate that to tighten or slacken the cable.. Try tightening it..
neilw
Post by neilw »
Cheers I'll give that a go first. If theres no improvement, I'll take it down the garage and see what they think.
alexperkins
Site Admin
Post by alexperkins »
Valeo LUK and Sachs are all OEM brands - it just depends whats available for that batch
neilw
Post by neilw »
Cheers Alex. They get there bits from TPS as its just around the corner.
alexperkins
Site Admin
Vw clutches are expensive though. It may be worth getting a price from gsf as they are the same parts
bradley1983
Post by bradley1983 »
I just had a valco clutch fitted as my gearbox was being done again. Cost me £120 all in!
S.Kayani
Post by S.Kayani »
I paid £180 for a sachs Clutch fitted with two year parts an labour warranty from mr clutch. Try getting a quote online :-)
neilw
Post by neilw »
