My mk3 coupe keeps cutting out on me. Ill start it but then when I drive to the end of the road and stop (junction) it cuts out and the alternator and oil light comes on. after driving for a bit it dont happen.
also when i'm indicating to the left a buzzing noise occurs. The left indicator was out so i fixed it but it still occurs. whats going on?
Having problems with car
robert.cheetham
Tahrey1043
- Location: Birmingham! Enjoys: The pseudo-G-Smiles provided by a 1.6 Megane Sport valver...
ooh wierd.... mine's messed up in the left indicator department too.. thought it was a unique problem
maybe we can get VW to instigate a recall
(bit of a bugger - you can't tell if it's properly engaged when the stereo's on without checking the dash light's flashing)
facetiousness:
1. you are remembering to put the clutch down when stopping right?
2. i'd like to lower the idle point if i can rather than higher if anyone can find the relevant thing to twiddle
slightly more efficiency.
facetiousness:
I had the same problem with my car cutting out at the end of my road when I was slowing down and had the clutch all the way down. I took it into the garge and they tweeked a few things but it still happened.
I then spoke so a VW mechanic who lives across the road for me, he didn't have any ideas apat from changeing the petrol from supermarkets to Essco, he said it many make it run a bit better, but I solved the problem. That was untill I move home and tryed BP which was worse it went back to cutting out and I had now power when pulling away, changed back to Essco, once I found a garage and it runs like a dream again.
