How do i remove the lower centre grille on the 6n2?
I need to replace it with the GTi ones...
A tutorial will be nice, else an explanation should be good enough.
Thanks in advance.
How Do i Remove the Lower Centre Grille...
Re:
Hmm.. My uncle is also having trouble removing the grille also on his car and when we've read this post, me and my uncle tried it out but still no luck and it won't even budge a bit. So my uncle's grille is also stuck like kapur, anyone have update on this thread or any DIY there how to do this thing. I'll appreciate any tips or suggestions.niks wrote:as far as i know there should be clips all around the grille insert three on the top and three on the bottom, took me 5 mins to replace mine with the gti one
- red6n2
Re: How Do i Remove the Lower Centre Grille...
it litterally is just clips mate it needs a good yank to get off and you will break some of the clips in doing so, only the side grills are secured by a screw
just pull firmly
When you pull it off, it will feel like you have broken a lot of things..but its just the clips on the grill.
- nigelelliott394
That's what I did.. I was replacing it so I just pretty much wrecked the standard one to get it out
