I have a grinding noise when am full lock to the left or right, for example, if i was to do a 3-pointer the grinding would be audible when reversing back on full lock and the again when driving off under full lock.
Its a metal grinding noise like a bag of spanners going through a wood chipper, lots of crunching.
i think its the drive shaft on the right hand side but not sure, any ideas?
Grinding Noise
Re: Grinding Noise
interesting mines doing the same thing. except its on the left side.
onces youve straightened up the wheel does the sound stop? or continue for a while?
My wheels coming off this weekend and its all getting throughly checked over
Re: Grinding Noise
only when the wheel is turned, its fine any other time.
- Endi_GTI
Re: Grinding Noise
Is it a constant grind on full lock or a knocking?
Re: Grinding Noise
its not a knocking its a grind when on full lock driving off. its like a spinning grinding noise.
- Endi_GTI
Re: Grinding Noise
hmmm not to sure on that one then dude. May be worth checking the CV joints etc although this usually is associated with a knocking noise. Sorry can't help much
