paining
Re: paining
http://www.uk-polos.net/view ... or#p126679
http://www.uk-polos.net/view ... or#p333733
The above might help a bit.
Take it slow painting
Spray from a good distance to avoid runs
Make sure each layer is dried properly between coats.
And with regards to paint I'm pretty sure Halfords do a sort of rubbery paint which comes out a bit like the original paint
Or Gloss looks quite nice £6.29 from Halfords from a medium can or £6.99 for a biggin.
Tho I think most people just end up buying new handles from VW if you want it to look original, neater, saving time and hasstle.
Hope this helps
Hope this helps
- Trottagti
Re: paining
If you have little experience in painting I would recommend taking your handles to a proper bodyshop as you need many materials to achieve even a decent finish.
I'm a professional spray painter by trade for Rolls Royce and bentley.
Time you have got all the stuff it ain't worth the time or hastle buddy.
Check my thread I have done all mine and dash etc....
- 6N2 GTI 00
- Location: North Wales, Denbighshire - Drives 255bhp EP3 Type R!
Re: paining
Its worth spraying the original handles because replacing them with new ones can be quite expensive.
I think both matt black and gloss black work well or you could go for a dark grey similar to the standard colour.
