Yes mate they will fit, but you will need different grills for the 9n as the 9n3 front end (inc all the grills/bumpers) are different. You can pick up some replacement 9n fog grills off eBay for not too much.... but make sure you get the loom off the 9n3 too as that can be expensive to buy from VW (relatively).
Also to run the foglights on a car without them, you will have to fashion and fit a seperate switch, or the better option is probably to buy an OE headlight switch from VW//off the 9n3 your using which has the foglight option (pulls out twice, first click is fronts, second click is front and rear). The non-front fogs models just have one click (rear fog). I guess you could just attach the wiring from the front fogs to the rear one so they both come on at the same time, but often you won't need the back one when you do need the frons (and no I'm not suggeting you drive around with the front fog lights on just because it looks "cool" haha!)
