Cornishdrummer's Progress Thread -Im back(pg 34)
Re: Cornishdrummer's Progress Thread -NOT HAPPY (page 4)
In what way do they not fit?
- cornishdrummer
The old ones (that came with the car) Fitted the whole gap, but the black ones dont fit as tight as them.alexperkins wrote:In what way do they not fit?
They fit into the clips and spring no prob at all, its just on the side where it meets the wing there is a very small little gap.
I got the new ones this morning and they do fit a little better, I will take a pic morro to show you the gap.
In a min I will put a pic up I took today.
- 6N2 GTI 00
- Location: North Wales, Denbighshire - Drives 255bhp EP3 Type R!
Just double check to make sure you have fitted them tight enough, its quite easy to think they are fitted because they are tight but they made need adjusting.
- cornishdrummer
There not in perfect, but are better then the set yesterday.6N2 GTI 00 wrote:Just double check to make sure you have fitted them tight enough, its quite easy to think they are fitted because they are tight but they made need adjusting.
The DS Needs playing around with a bit more.
But the PS Is near enough spot on.
- cornishdrummer
Here are two pics I took of them today.
And also a pic of my new sticker I fitted yesterday
Comments please
- 6N2 GTI 00
The drivers side looks pretty tidy but the passenger side needs a bit of work to get it spot on.
Are you planning on getting a set of Angel eyes to match your smoked indicators?
- cornishdrummer
The prob is, the passenger side one is the better fit and you cant move it when its cliped in place, but the drivers side one you can.6N2 GTI 00 wrote:The drivers side looks pretty tidy but the passenger side needs a bit of work to get it spot on.
Morro I will take a pic of each side to show the gaps and the way they are fitting.
Not sure really, aint thought about it to tell you the truth.6N2 GTI 00 wrote:Are you planning on getting a set of Angel eyes to match your smoked indicators?
Was looking for a set of black rear lights today tho.
Re: Cornishdrummer's Progress Thread - New Pics (page 5)
You may need to file the groove deeper in the top of the indicator. Its a common problem with aftermarket indicators on the 6n2
- 6N2 GTI 00
If you have any more problems then it may be worth putting the originals back on but having them tinted with either tint spray or film. I thought you would be looking to get a set of smoked headlights too because it might look a little weird having smoked indicators and clear headlights.
Its all personal choice though
- cornishdrummer
Any tips on the best way to to this with out messing up big timealexperkins wrote:You may need to file the groove deeper in the top of the indicator. Its a common problem with aftermarket indicators on the 6n2
- cornishdrummer
I really want to get these ones to fit if I can, coz I do Like them.6N2 GTI 00 wrote:If you have any more problems then it may be worth putting the originals back on but having them tinted with either tint spray or film. I thought you would be looking to get a set of smoked headlights too because it might look a little weird having smoked indicators and clear headlights.
If I could get smoked headlights for a good price it might sway me
Small sharp stanley bladecornishdrummer wrote:Any tips on the best way to to this with out messing up big timealexperkins wrote:You may need to file the groove deeper in the top of the indicator. Its a common problem with aftermarket indicators on the 6n2
- cornishdrummer
Im guessing Alex this will help the fitting at the back near the wing as well ?
- cornishdrummer
Would I be able to see the diffrence between the two, or is hardly anything.
