Hi Guys, Going to be replacing my front wheel bearing this week, I'm familiar of what needs to be done, just wondering if anyone has done one before and IF they needed a special tool to get the old bearing out or can it carefully be tapped out with a hammer?
Front Wheel Bearing DIY Replacement
Re: Front Wheel Bearing DIY Replacement
Doesnt the bearing need to be pressed in ?
If it doesnt go in straight, it will only last a few hundred miles tops
To remove youll need a bearing extractor, to fit it needs to be pressed in
- joe2612
- Location: Guildford, Surrey, Drives: Polo GTI 6n2 Black
So is that more or less a garage jobby?
On these, yes as the hub is a pain in the ass
- joe2612
Could i remove the swivel hub completely, and take that to a garage for the bearing to be removed and new one pressed in to save unnecessary cost?
So no chance removing if with a soft mallet?
You could if you wanted to!
And no, not a chance, It takes a hydraulic press to get them in/out without damaging the hub on the GTI
