Air Filters
Scotty9n
Air Filters
Post by Scotty9n »
Looking for An Air Filter Any1 recommend any thing?
just after a panel filter,
im running a 9n 1.4 ? ? seen some for 1.8s but guess that'll do?
g__humm
Re: Air Filters
Post by g__humm »
Don't think so as the 1.8 is turbo so is a differnt air box to urs I think
Dub_Dan
Re: Air Filters
Post by Dub_Dan »
dude can i ask why you want a filter? they dont really give bhp gains in some cases you lose some bhp due to the heat soak i would upgrade the panel filter. unless you just want noise which is understandable :D
Scotty9n
Re: Air Filters
Post by Scotty9n »
looking at the panel cause i dont wanna have to take the engine cover out so unless you know how to fit the cone filter and keep the engine cover in ??
g__humm
Re: Air Filters
Post by g__humm »
Just go with a pipercross
Keeno21
Re: Air Filters
Post by Keeno21 »
No idea if BMC make a filter for the 9n, but if they do that'd be the one I'd recommend. They don't come cheap though!
Scotty9n
Re: Air Filters
Post by Scotty9n »
I have seen BMC panel filters?
Keeno21
Air Filters
Post by Keeno21 »
They also do a CDA (carbon dynamic airbox IIRC) which is an enclosed cone filter with a cold air feed. They do them for the 6n/6n2 but charge over £100...
Dub_Dan
Re: Air Filters
Post by Dub_Dan »
mate just change the panel honeslty i cant justify changing to an enclosed induction kit or open filter induction kit unless you want noice the bhp gains dont justify £100+++ the standard air box is designed to work well with the car you may even lose bhp with an open filter but gain a couple with an enclosed with a good air feed...
Keeno21
Air Filters
Post by Keeno21 »
TBH, I like the CDA kit cos it looks pretty!
Dub_Dan
Re: Air Filters
Post by Dub_Dan »
agree with what you say but i think just the panel should be changed i think the engine should be left standard as its not really a tuneable engine but i would like the cda just for the sound but it is expensive...
:D
K.I.T.T.
Drives: Bicycle
Re: Air Filters
Post by K.I.T.T. »
Keeno21 wrote:TBH, I like the CDA kit cos it looks pretty!
I used to have an ex like that... :?
Ash :)
Keeno21
Air Filters
Post by Keeno21 »
Zing!
