Itll be the microswitch in the boot locknigelelliott394 wrote:My LED bootlight stopped working tonight. I noticed it flickering a couple of days ago but when I opened the boot this evening it wasn't on at all. I tried swapping the bulb around to see if that helped any but to no avail. I'll need to get a look at it in daylight to see if I can see anything glaringly obvious.
Any ideas? It was a fairly expensive LED I put in there too from Ultra-LED's so I'd be kinda disappointed if it was the bulb. Definitely cost me more than a tenner too
EDIT Just tried the old bulb in the holder to no avail, must be a fuse or a wiring issue.
Does the boot open light show on the dash when the boot is open and the ignition on?
