Retro fitting central DIS
Keeno21
Post by Keeno21 »
Can it be done on the 9n? Having gone from an A3 20VT with the big central DIS, having the small one in the rev counter keeps confusing me!
blazeguarder
Re: Retro fitting central DIS
Post by blazeguarder »
Yep, it can be done. Complete effort though because you need to recode the immobiliser once you've changed the cluster, and it's quite difficult to find used clusters with the screen as they only came with the nav option, which nobody bought because it was expensive. New clusters are quite expensive as well.
Here's a guide, in typical Google Translate German :roll: : http://translate.google.co.uk/translate ... rmd%3Divns
Keeno21
Post by Keeno21 »
Sod that for a game of soldiers then! I was hoping that it would be possible to fit just the DIS without changing the entire cluster. I should have known better really!
