TDi sport throttle body cleaning
Keeno21
Post by Keeno21 »
How do you reset the butterfly afterwards?
The throttle seems to stick momentarly when it's fully open, I've got no experience of the pd engines but even so, I'm assuming this isn't normal?!
K.I.T.T.
Drives: Bicycle
Re: TDi sport throttle body cleaning
Post by K.I.T.T. »
Diesels don't have throttle bodies ;)
I'd check it over with VAGCOM for fault codes first.
Ash
g__humm
Post by g__humm »
Should stay open and only shut when you turn it off
Keeno21
Post by Keeno21 »
K.I.T.T. wrote:Diesels don't have throttle bodies ;)
Every day's a school day! They must have some sort of valve (butterfly or otherwise) to control air flow though?
g__humm wrote:Should stay open and only shut when you turn it off
I ment that it sticks full open momentarily despite my foot being off the loud pedal...
g__humm
Post by g__humm »
The bit u see is the anti shudder valve a diesel reving is controlled by the fuel rather than the air. I have removed mine so I have no valve.
Keeno21
Post by Keeno21 »
How does that affect running? I assume it improves it else you wouldn't have done it, unless of course you're just a little bit mental...
g__humm
Post by g__humm »
Allows smoother air flow.
