Hooked upto diagnostics and recieved the following codes
- P1519 Camshaft adjustment malfunction intermittent
- F129 Aircon pressure switch (re-gassed the aircon and this seemed to solved the problem here)
Can anyone shed som light on either of these codes and their respective underlying causes?
Dan
Help with error codes
Re: Help with error codes
17927/P1519/005401 - Camshaft Adjustment Bank 1: Malfunction
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Possible Causes
Fuse(s) faulty
Camshaft Adjustment Valve Bank 1 (N205) faulty
Wiring and/or Connector(s) from/to Camshaft Adjustment Valve Bank 1 (N205) faulty
Possible Solutions
Check Fuse(s)
Check/Replace Camshaft Adjustment Valve Bank 1 (N205) Perform Output Test/Basic Setting
Check Wiring and/or Connector(s) from/to Camshaft Adjustment Valve Bank 1 (N205)
found this on a website, where is the equipment referred to in the solutions?
Possible Symptoms
Possible Causes
Fuse(s) faulty
Possible Solutions
Check Fuse(s)
