The same style of wheel used by the touring car racers; light and strong.
7x16''
4x100 PCD
Spigot rings to fit VW 57.1mm centre bore.
These have been on my daily driver for a few years now, but I've put the car back to more or less OEM spec so the wheels are up for sale.
They're fitted with Falken 512 tyres, 195 45 16.
Again the tyres have been on my daily driver for a few years so are reaching the end of their life.
However both the wheels and tyres would be ideal for the trackday season approaching.
I'll list each wheel and tyre condition seperately, tyre tread taken from central 75% grooves:
#NSF, kerbed for half of diameter and touched in with black hammerite, tyre very worn on outer shoulder, tread 4mm 3mm 3mm
#OSF, wheel good, few stonechips, tyre again with heavy shoulder wear, 4mm 3mm 4mm tread
#NSR, wheel good but with some light surface scratching, 1 puncture repair (recent and receipt included), tread 4mm 3mm 4mm
#OSR, wheel and tyre both good, 4mm 3mm 4mm
The description above sounds pretty negative but in the flesh they actually look quite good, they've been well looked after apart from the one wheel my wife managed to kerb.
No bolts unless you can swap me a set of standard VAG bolts
Price: £240
Collection only from Exeter (Devon), I don't want to courier these
