Rear Brakes
Erkan
Rear Brakes
Post by Erkan »
Anyone fitted rear disc brakes to their 6n? If so which ones, and would mk5 gti ones fit?
any comments appreciated.
l0rne
Re: Rear Brakes
Post by l0rne »
the mk5 gti ones fit straight on, any mk5 with rear discs can bt mk5 r better
Erkan
Re: Rear Brakes
Post by Erkan »
awesome, cheers man. Now I just need to go out and buy some.
alexperkins
Site Admin
Re: Rear Brakes
Post by alexperkins »
Youll also need the related parts such as GTI rear hubs and disc brake handbrake cables
The easiest option by far is to just swap the rear axle
sixen
Re: Rear Brakes
Post by sixen »
6n2 beam dont fit a 6n, different bush set up/size apparently. but everything off it will bolt onto a 6n beam.
alexperkins
Site Admin
Re: Rear Brakes
It will fit with a bit of work
sixen
Re: Rear Brakes
Post by sixen »
just a quick update, 6n2 rear axle WILL NOT FIT a 6n, the mountings are totally wrong. have pics will upload :D
