Wheel bearing
red6n2
Wheel bearing
Post by red6n2 »
So there's a slight grinding noise coming from my front drivers side wheel I assume it's the wheel bearing, and it wasn't that bad till my 200 mile round trip yesterday now it's louder but am I best off replacing both sides at the same time or just the knackared one ?. Cars done extensive mileage and have no idea when they were last changed I can't ever remember having done them.
alexperkins
Site Admin
Re: Wheel bearing
Post by alexperkins »
if you are doing one, id be inclined to do both personally for symettry
Monkey-Man
Re: Wheel bearing
Post by Monkey-Man »
General rule of thumb, dont fix what isnt broken!!
Like i said its general, when replacing stuff like arb/wishbone bushes or topmounts then replace both sides as obviously replacing one side will have a negative effect on performance. However if your wheel bearing isnt gone on the other side there is not point replacing it with a newer one as it is going to be no more efficent than what you already have.
Dont make work for yourself mate, especially where there is no benefit to be gained!
red6n2
Re: Wheel bearing
Post by red6n2 »
yeah moneys running low and its only the 6th so think it may have to be just the worn side,
thanks, for your input mate, much appreciated, :D
alexperkins
Site Admin
Re: Wheel bearing
Then again the other way to look at it is youll need to get the car camber and tracking etc done as the hub will likely be removed to press the bearing in/out, and for the cost of a wheel bearing its worth the extra effort as it is likely the other wheel bearing will fail in future and the same will happen again.
red6n2
Wheel bearing
Post by red6n2 »
Just when I thought I was out they keep pulling me back in...
Money could be very tight this month il have to speak to my garage ask about costs Of a singular exchange to both sides.
alexperkins
Site Admin
Re: Wheel bearing
It really depends on if your garage has the tools to replace the wheel bearing in situ like VW can do without removing the hub from the car
