clutch question
Dub_Dan
clutch question
Post by Dub_Dan »
i upgraded my clutch to the sachs clutch when 10000 miles ago although my garage said that i never need to change the flywheel? due to the flywheel not matching does this mean that the gear changes wont be as smooth? just a though as im thinking of going single mass
thanks
g__humm
Re: clutch question
Post by g__humm »
I have single mass. If you come tomorrow you can hear it lol. Engine mounts maybe gone, to check try to pull away with handbrake on and have someone watch ur engine, if it moves more than 15 degrees (if it standard mounts) then they are gone
JonnyBCK
Re: clutch question
Post by JonnyBCK »
i also have the sachs clutch and as far as im aware the flywheel was never changed and it has been like this for over 3 years and never had a problem. i will dig through my reciepts i got with the car to double check but i never seen one the first time i looked through, i will not be home to do this till the 20th of july though.
