1.4 16V AHW PINKING Grrr!
craggles
Post by craggles »
Been happening for a while now,the dam thing is pinking under load and im not sure where to go with it,so i thought id ask on here if anyone has experianced it and how/if they solved it.
Ill start of by saying what i've done so far which isn't much :mrgreen:
Checked sparked plugs are correct
Had cambelt done anyway so had the timing checked twice (it did it before the belt change)
Blanked of EGR at throttle body and still did it
Throttle body was cleaned march 2010/reset
New engine temp sensor fitted same time as throttle body
Using standard unleaded in the car
I'm pulling my hair out now on what else to do with it,I understand the knock sensor could be faulty,but I have never had an ECU light throw up on the car yet,and its just past its M.O.T so maybe rule out lambda sensor/s.As th timing is done via the ECU there is nothing I can about that area.
What else would be causing this issue?Really appreciate 'any' ideas big small,trivial or technical..thanks alot :mrgreen:
craggles
Re: 1.4 16V AHW PINKING Grrr!
Post by craggles »
Sorry mods think this should be in the MK4 section,as mine is a 6n2 W reg
f6had
Post by f6had »
It's a MK5 mate.. what is the condition of your o2 sensor?
craggles
Post by craggles »
f6had wrote:It's a MK5 mate.. what is the condition of your o2 sensor?
Im not sure TBH as ive not taken it out,there is 2 on the car in total.,I thought it may have thrown a light up if it was something to do with them??
And thanks,thought it was MK4 lol so im in the right place :mrgreen:
thing is driving me mad,,Im told knock sensor could be at fault,or just loads of carbon in the engine 102k its done.
craggles
Post by craggles »
Anyone know if this could be caused by carbon build up,and is there anything on the market that will clean out the carbon without removing the head??
ive come across Wynns Combustion Chamber and sefoam think it is both require it to be taken in via a vaccum intake.
Bepe
Post by Bepe »
i had this exact same problem on mine. I unplugged my egr valve and was fine. Had the engine light on but that never bothered me and the car ran alot smoother and quicker
craggles
Post by craggles »
Hi mate,thought about the EGR,but its a mechanical one,the one thing I can unplug from it is a vaccum pipe,Ive read about the electronic EGR's where people have unplugged the power to it and its solved it.
What I did try was I made a complete gasket and blanked it of at the throttle body,but it made no difference really.
Going to get a price for a compression test today and see if its carbon on the engine
littlepolo
Post by littlepolo »
How did the test go? I have the exact same problem on a 45K mls 2003 Polo.
craggles
Post by craggles »
not had it done yet mate,im getting it done next week,,you may have a electronic egr on yours,try unplugging it then give it a drive.
Is yours doing it through all the gears?
