Thanks for the feedback Jamie.
JamieG172 wrote:but alot of people are adding foglights to basic spec cars that didn't come with them originally, which tends to also mean there are a lot of blank switch covers on the dashboard by the Hazard Lights button - maybe retro-fitting a switch in here would be a possibility?
FWIW, this is what my Sport dash looks like (ignore the lack of everything, just look at the row of buttons at the top)
As you can see, the "not so basic" spec cars have lots of blanks as well
All I've got is a hazard warning lights switch and rear demister switch.
A suitable OE switch that'd that'd fit in that row and work with fog lamps doesn't actually exist, so you'd have to use another switch and it'll end up looking like a botch. I think the OE headlamp with front fog capability switch is the way to go.
On another note, I'm also thinking of putting retrofit cruise control kits together. You can currently get them for £100 posted, but they don't work with the 1.2l models. I reckon I'll be able to do a kit for around £15 less which'll work with
any engine.
Ash
