door latch
door latch
i recently changed my door handles on my 4 door 9n3 hatch, by removing the little grommet in the door, removing the little rear piece first and then the handle and then replacing with the new ones and doing everything in reverse order, and about 2 days later, i discovered my passenger door and rear right door would not open even once the car was unlocked, i then by chance discovered i had to push against the door from the outside and hear a click sound and then only would pulling on the handle open the door. Has anyone experienced this? what is the cause and how does on fix it? i heard it is something do with the latch configuration (thus needs to be reconfigured) or something like that
