how low should i go ?
lukey GTI
Post by lukey GTI »
I was going to get coilovers but i carnt afford :oops: lol
so im going with some lowering springs .. just how low should i go ? :?:
Dub_Dan
Re: how low should i go ?
Post by Dub_Dan »
30mm mate any lower the life of the shocks is going to be an issue especially if your doing this on a budget as you said you cant get coilovers
lukey GTI
Post by lukey GTI »
Dub_Dan wrote:30mm mate any lower the life of the shocks is going to be an issue especially if your doing this on a budget as you said you cant get coilovers
suppose that's low enough tho on springs ... yeah atm im on a budget still paying for the car lol
when its payed i mite go abit mad :twisted:
thanks lad
v896
Post by v896 »
when considering lowering you also put strain on other parts of the suspension system i.e bushes dampers, shocks absorbers, bushes, top mounts etc... best to consider getting a suspension kit coil overs are cheap cost you more in the long run as other parts of the suspension. if your going to keep the car for a long time get a full suspension kit if not then best to just get coilovers depends how much your bushes are worn aswell
H&R are on offer
http://www.venommotorsport.com/manufact ... Suspension
£155 inc VAT and delivery just for springs
Dub_Dan
Post by Dub_Dan »
yer mate no worries go with the more popular brands eibach, kw, H&R, not sure if weitec do any...
lukey GTI
Post by lukey GTI »
thanks V896
i was thinking of getting ARBS + strut brace and changing my bushers .. dont know much about bushers tho to be fair .
i will get a suspension kit or coil-overs at some point just not any time this side of xmas
yeah will do dan lad thanks
any one of USC santa pod ?
Dub_Dan
Post by Dub_Dan »
bushes get some seat cupra ones or polybushes... makes the car stiffer and gear changes smoother...
BennoGTi
Post by BennoGTi »
lukey GTI wrote:any one of USC santa pod ?
I'm at USC this year again :twisted: :twisted:
I used to run Eibach 30 mm springs on my GTi, but it hardly looks lower than standard I found :(
Yeah it feels a bit stiffer and handles a bit better but looks pretty miuch the same as your only taking it 15mm lower than you are now, not 30 mm
The same springs are used on the standard polo, so the "30 mm" drop is from standard, the GTi is already lowered 15 mm, so the overall drop for you will only be 15 mm
I ended up changing them for coilovers after a few weeks
lukey GTI
Post by lukey GTI »
ahhh true benno i may see you there > u running the car over 1/4 mile ?
what coilovers do you have any links for a site ? thanks
matt_123
Post by matt_123 »
http://www.venommotorsport.com/manufact ... =Coilovers
save up mate and get coilovers be a waste getting springs as you wont really see the difference and you will want it lower within a few hours of looking at your car with the springs on! lol
lukey GTI
Post by lukey GTI »
matt_123 wrote:http://www.venommotorsport.com/manufact ... =Coilovers
yeah lad actually you are right bit of a waste of 140 quid n fitting time ... mite as well save a that n get em in like 2 months time made me see sense lol :)
Oldfella
Post by Oldfella »
I put some H&R springs on my TDI and it made loads of difference, There Is only 25mm if that between the arch and the standard alloy!
matt_123
Post by matt_123 »
Oldfella wrote:I put some H&R springs on my TDI and it made loads of difference, There Is only 25mm if that between the arch and the standard alloy!
25mm still quite a bit though mate ;) coilovers ftw! give it some time and you'll wish you had them its part of owning a vw coilovers and slammage. also your tdi wouldnt come 15mm lower like the gti's or sports.
SerahGTI
Post by SerahGTI »
Hi. I am new to this site. I purchased lowering springs 30mm and they made no difference to my car. I advice to get coilovers.
I also went to USC at Santa pod this year, i did the 1/4 mile and got a 14.3 which isn't that I'm a girl. :lol:
Good luck.
Oldfella
Post by Oldfella »
It's a tdi sport! I need a little clearance as the boot is often full of gear or kids in the back! It sits nice but it Certainly ain't slammed to fleck lol!!
