HOWEVER, on my Passengers side window, both 'clips' seem to be fine, but when you press the switch (on both sides) all it does is:
Makes a 'Whir' noise for half a second then a 'Duh!' and stops.. Does this pressing the button up or down..
I've checked all the Fuses, and the Wiring for Voltage and Continuity (Especially checking in the Rubber between the Door and Body..) All seems OK..
I tried a little gentle pressure on the glass, but it does nothing.. Any ideas?
AND.. How do you get a Regulator 'Out' if the Window is stuck in the 'Up' position as you can't undo the glass mounts..??
This is the ONLY fault with my now car and it's really bugging me.. Any HELP.. Please!!
