would like to know if 9x17 would fit at front on a 9n3?
The ET is 47 but will have to run adapters cause the PCD is 5x112!
Which ET would be optimal?
Any info or pics are welcome!
Denis
9x17 at front on a 9n3?
Re: 9x17 at front on a 9n3?
yes it will fit,the best et is 30 for the polo 9n3, but it would be better an 8,5
I used to run 17x8.5 et30 and it rubbed like a bastard!
dood9n3
17X7.5 Ariettas et 38 rub with 205-40-17
- whitegtipolo
8 inch max tbh
I agree, there are folks on her who I've seen run 9" on a 16 but not on a 17".whitegtipolo wrote:8 inch max tbh
Personally I wouldn't go anything over an 8. My rotiforms were 8.5 and they rubbed so had to raise the car quite alot.
- whitegtipolo
I had on my old 9n3 8x18 35mm offset and just fit had to pull front arches out and going 9 inch you would have to go 30 mm offset as so close to shocker , must say the arches are thin and can be manipulated easily old polo below
dood9n3
Please can you show me pics of the arch work you had donewhitegtipolo wrote:I had on my old 9n3 8x18 35mm offset and just fit had to pull front arches out and going 9 inch you would have to go 30 mm offset as so close to shocker , must say the arches are thin and can be manipulated easily old polo below
thanks for your input guys!
will probably go for 8,5 at front and 9 at the back!
dood9n3 wrote:Please can you show me pics of the arch work you had donewhitegtipolo wrote:I had on my old 9n3 8x18 35mm offset and just fit had to pull front arches out and going 9 inch you would have to go 30 mm offset as so close to shocker , must say the arches are thin and can be manipulated easily old polo below
+1 for pics of the arch work, im also keen on running 9inchers
sorry i got the ET wrong, u have to have a ET25, if u put BELOW susp. it will never rub, on my bmw 320 year 1996 i had 10j ET18
