Driveshaft seal leak? Help Please!
CB_polo
Post by CB_polo »
I lowered my car about 70mm a couple of months ago, i had the car on a ramp yesterday and found a couple of leaks, which was coming from both sides of the gearbox. i was just wondering if someone could shine some light and tell me if they've experienced the same thing, and if theres something that'll sort it out.
Maybe bigger wheels and raising it slightly?
Thanks!
Re: Driveshaft seal leak? Help Please!
Just one thing, you've dropped the car suspension and changed the drive shaft angles - fitting bigger wheels will raise the car back up off the ground but these drive shaft angles will remain the same - think about it!
