Just a quick silly question..
How to i get to the bulbs in the central roof console and units under the sun visor?
Is there any technique or is it just 100% bravery?
Interior Lights
Re: Interior Lights
The sun visor ones slide one way. Can't remember which. Can't even remember how I did the centre one. So I'm not much help haha
Be carefull though as they are both very easy to break. Which I found out
Re: Interior Lights
Ok cheers anyway mate!
I managed to pop the visor ones out.. But the central one just didn't want to budge and i don't really fancy breaking it!
Any ideas anyone??
Any ideas anyone??
K.I.T.T.
- Platinum Member
- Drives: Bicycle
Re: Interior Lights
Did you manage to get the centre light unit out at all? Just pull it out. It's clipped in.
Ash
Ash
Re: Interior Lights
Is it.. I did try but it was a bit scary! haha Sweet cheers mate!
Do i pull on the whole thing or try and prize the lens itself out?
- blazeguarder
Re: Interior Lights
Pull off the trim piece behind the light unit and then you can get your hand in to pull it out. If you really want to then you can prise the plastic lens off and bend the clips back but it's not necessary to do as it comes out so easily with a bit of a pull.dje123 wrote:Is it.. I did try but it was a bit scary! haha Sweet cheers mate!
Re: Interior Lights
with my centre light the cover has a couple of little prongs just holding it in place, just prise and pop it out =)
Re: Interior Lights
Yeah just prise at the bulb cover plastic to get it off, take bulb out with fingers and then unscrew the screw underneath the bulb, now you can prise the whole unit out if needed. I noticed this when fitting my Parrot handsfree microphone as its fed up behind the steering wheel up through the side sill and into the roof lining, then it pops out through the light assembly and is mounted on my sun visor. Very neat!
