Hi all,
Thought I'd put this in here as this part of forum gets more traffic. I don't mind if the mods want to move it though.
So today's hot topic for me is. Does anyone know the part numbers for the heated leather loom, switches, relays etc from the polo?
As some Of you know I have Neil's old car now and it has the leather seats fitted. I've not looked properly but I believe Neil said the looks are there with the elements etc so I'd like to get the heaters hooked up and working. I do however want to retain the OE look.
I've had a look on eBay for switches but there seems to be multiple part numbers for the VAG stuff on there, so does anyone know what the Polo part number was?
Failing that is there any auto sparks on here who may be able to tell me what size cable/fuses & what relays I'd need (I assume I'll need some relays) so I can make up a loom myself
Steve
Heated seat part numbers
SteveHawkins
Re: Heated seat part numbers
Righteo fella, you'll need to get the switches off TPS. (Remember them retailing at around £40 per switch if I recall correctly, that was over a year ago and that was at retail price.. not sure how much now) In terms of the wiring loom, its £42 from kufatec. (clicky here!) Simples
How easy is it to wire the seats up? I get the plug in and play but where do the wires go?
SteveHawkins
Trunkz wrote:Righteo fella, you'll need to get the switches off TPS. (Remember them retailing at around £40 per switch if I recall correctly, that was over a year ago and that was at retail price.. not sure how much now) In terms of the wiring loom, its £42 from kufatec. (clicky here!) Simples
Exscuse my ignorance, I'm new to the VW side of things
Steve
Trade Parts Specialists. Do a google searchSteveHawkins wrote:Trunkz wrote:Righteo fella, you'll need to get the switches off TPS. (Remember them retailing at around £40 per switch if I recall correctly, that was over a year ago and that was at retail price.. not sure how much now) In terms of the wiring loom, its £42 from kufatec. (clicky here!) Simples
Exscuse my ignorance, I'm new to the VW side of things. Whats TPS?? The Polo Shop perhaps? web link anyone? Please?
Steve
