Rear tinted lights.
- Boyracer_2011
- Drives: 1.2 Moda
Rear tinted lights.
Iv seen these lights on a German website and thought they look canny nice. What do you think??
Anyone know what part number or if its available in this country to buy. Thanks.
- NeilMcConville
Re: Rear tinted lights.
That rear bumper doesnt look too bad now!
Im also interested in these rear lights... So far ive contacted one dealer in Germany and was told it would not fit rhd models. Part number i have is 6r0 052 200 8rz
Wow what rear bumper is that?? Looks mad!!
- Boyracer_2011
- Drives: 1.2 Moda
Cheers Lesgodoy for the part number. Aye that bumper does look mental like lollesgodoy wrote:Im also interested in these rear lights... So far ive contacted one dealer in Germany and was told it would not fit rhd models. Part number i have is 6r0 052 200 8rz
Found another pic, id luv to get some. Think it would look sweet on a white car
- blazeguarder
Aren't those UK spec lights? Fog's on the right hand side whereas it's on the left on the continent...Boyracer_2011 wrote: Found another pic, id luv to get some. Think it would look sweet on a white car
This is pics of white POLO with ''black'' lights:
- Boyracer_2011
- Drives: 1.2 Moda
ErkoSlo wrote:This is pics of white POLO with ''black'' lights:
Now that looks lush mate, do you know if they would fit on the UK spec model and able to change the rear fog light over?
I wish my car looked like that
Ask local VW dealer, this is OEM VW lights and they sold them!
- Boyracer_2011
- Drives: 1.2 Moda
Yeah will do mate.
I was just thinking I dont use the rear fog light anyways so should be alright, shouldnt it???
However, you can ask if the lights are available for the UK market. These are the lights:
http://www.volkswagen-zubehoer-shop.de/ ... razit.html
I'm almost 100% that they are suitable for yours.
- blazeguarder
You'd need to do a bit of wiring work as if you fitted European rear lights then the 'reverse' light would come on instead of the fog and vice versa. Alternatively, there's probably just a red filter inside the lens, so if you're feeling brave you could just break it off so you could use the 'fog light' as your reverse light as it wouldn't be red.Boyracer_2011 wrote:Yeah will do mate.
I seem to remember reading somewhere that it was compulsory for RHD cars to show a reverse light on the left and a fog light on the right. Don't quote me on that but could be a problem come MOT time if it's correct...
Reverse lights aren't needed for an Mot however a rear foglight on the offside is a must, will fail without one.
Swapping the fog and reverse sections should be doable. I did it with the MKV Golf LED rears. The only issue would be if the red and clear filters are moulded into the surrounds.
look good on a black car and I've been considering taking the plunge on these for a while.
Worst case scenario is that the filters aren't interchangeable and I have to cut them out to swap them over and plastic weld them back in. Done it before and it works fine. Just don't try superglue as it fogs the plastic.
