Polo bits for sale. Lots !
Forum rules
Please Use The New FOR SALE CATEGORIES when listing an item for sale!
NotRich
Post by NotRich »
The Salsa is naked:
Violated :
Buried :
:( Now to sell it off in little bits.
Engine conversion complete £900
This includes:
Engine (complete) with flocked cover, serviced about 30 miles ago with genuine vag items.
Gearbox both on 68556, service history and clocks show this.
Subframe (front with thicker Lupo GTI roll bar and wishbones)
Pedalbox & hydro clutch set up, potentiometer and all pedal switches, all pipes and clips.
Shifter mech.
Loom for whole car front to back, door looms and tailgate, the relays, ecu, everything you need for the whole car. 6N or 6N2.
Clocks for the car, everything needed for the immobiliser
Alarm sensors, key, lockset, CCM, everything will be the same as a GTI. Electric everything, the alarm, remote central locking.
All waterpipes and nine month old radiator.
Full exhaust, front to back, cats, lambdas, manifol, everything.
Sacred 6 speed gearknob to allow inner smugness as you have that 'sixth' gear feeling. Can't emphasise how much better the shifting is, and the light clutch.
Basically everything you need to convert any 6n or 6n2 to a fully functioning individual 6 speed GTI.
The loom will be labelled (if needed) and everything is bolt on/bolt off. It's a straight forward conversion, the 6n2 bulkhead even has the hole/bolts out the factory for the pedalbox. I'll also include the vag blank for where your current clutch cable is.
All lights light up/off as they should. Fault code free. Everything is in tip top condition, gotta show the car the love.
If wanted, you can even have the rooflining which has the cut out for the internal alarm sensor which is included naturally.
This will pretty much complete any car & I will be on hand for stupid questions.
If you're putting this into a GTI, it's a bit less complicated and you'll probably have to PM me to ask stupid questions.
Keep in mind if you are doing this in a GTI, you'll actually have a whole conversion to flog on yourself after doing this, good for other Polos or even Lupos as most of those like putting the Polo engine in as you don't have to change the stuff you've gotta change. It's not hard, they're all just lazy.
This would even fit in a Lupo, you'd just have to change a few more bits and run a Polo loom.
Just be aware this will transform your car and there isn't another like it out there. It was awesome.
Everything isn't pictured, just some basics.
Seats £250, colour concept mk3 golf recaros, front and rear with Polo mk5 backplates.
Seats have minimal wear, bit wear on drivers bolster, will come cleaned/treated.
Door cards £50, TDI SE ones, same as GTI ones but black, so much nicer than dirty looking red ones. Front and back, just forgot to picture the fronts. Rear speaker plates for behind are included with this, just need rivetting in place. Speakers are not included.
Brakes front £100 (dibs has been called), 280 conversion, recently painted red with Brembo discs and Pagid pads.
No play on bearings, comes with hubs, abs sensors, rings, ball joints, hoses, everything you need to bolt on.
Rear beam £80, Pads discs in okay nick. Hoses are intact, as are handbrake cables and ABS stuff, no faults with sensors, bearings fine.
Wheels £450, 15 x 8 Schmidt modernlines, recently refurbed. kerbing on passenger front, minimal.
195/45/15 Proxis, tyre scrub on rears, great tread. Fronts, not great at all.
I apologise for not cleaning these first, I've been busy, it's Christmas eve and I'm lazy.
Front lights £80, xenons, all work, brackets are a bit hoopty and the passenger side is a bit rapey in general, yes that is fibreglass and rape tape.
Indicators £15, bought new and they're in clear condition.
Grills £50, all the grills for the front, all honeycomb, clips knackered on the main one, zip ties work well.
Splitter £10, fairly hoopty, it once fell off and got ran over. could benefit from zip ties but fits up and looks fine. Killed a rabbit once.
Suspension £110, front and back Joms, near enough new, never ran over winter, no corrosion.
Rear lights £40, rear lights really, all red 6n2 things.
Shafts £40 pair, all good, bearings are good.
Parcel shelf £15, in spot on condition.
Window switches £30 pair, all work, go up and down with no complaints.
Window mechs £25 each, same as above.
Mirrors £30 pair, standard GTI heated/electric beadle syndrome mirrors. Green casings.
Stubby mirrors £40 pair, casings in primer, need to chase Panda up for the glass.
Aerowipers £60, from a Lupo GTI, in good shape, recent blades.
ABS pump £30, Polo GTI abs pump, worked fine.
Central locking pump £25, works fine, moderately priced!
Headlight protectors £15, comes in near new condition, all brackets attached.
Custom seat loom £40, run your mk3 heated seats in a Polo mk5 with Polo switches (included) easy installation.
Stalks £10
Fogs £30
Door locks, internal ones £10 each
Ac control panel £15
Door catches in silver, shiny and a nice upgrade to 6N's. £
Dash conversion, heaterboxes, all the plastics inc glovebox and vents etc. . . £30
Sunvisors and the centre bit £10
Inside light £6
Jesus handles £6
Mirror switch £6
Headlight switch, front and rear fogs £8
AC heater box, worked fine, £10
Carpet, side trims, C pillar plastics £10
Pick up from Birtley ideally, can meet at the Roadchef services in Durham, items posted will generally be couriered using Paisley Freight. Fun times.
cornishdrummer
Re: Polo bits for sale. Lots !
Post by cornishdrummer »
Headlight protectors are only £8 on ebay
NotRich
Post by NotRich »
Genuine ones ?
alanjwong
Drives: 2001 VW Polo 6N2 1.4 16v 100BHP
Golf Mk3 Colour concept seats
Post by alanjwong »
Hi mate,
Have you got any photos of the Golf MK3 Colour Concept seats? Im interested.
x3ro
Post by x3ro »
Any photos of the door cards? Interested in those if they're in a good condition
NotRich
Post by NotRich »
I'll get some pics up next week when it's stripped.
Seats are okay, doorcards are absolutely spot on.
benmkiv
Post by benmkiv »
Let me know a price for the gti lights mate? Would like first refusals depending on price and money ;)
NotRich
Post by NotRich »
Do you mean the ones already priced above ?
benmkiv
Post by benmkiv »
Pm'd I believe
NotRich
Post by NotRich »
Pm'd back I believe.
vr6south
Post by vr6south »
Is the price £15 for both front indictors (the ones which sit next to the head lights)? And are the tabs intact?
M54 SINGH
Post by M54 SINGH »
how much would your take for the front headlight covers?
NotRich
Post by NotRich »
It's for both, I bought them new last May and they're all intact.
Still got the reciept too, genuine Hella items, not aftermarket crap.
As for the front lights, the price is up there, why can't anyone see it ?
vr6south
Post by vr6south »
NotRich wrote:It's for both, I bought them new last May and they're all intact.
If it's the two which sit next to the head lights I'll 100% take them. If you can post them say £18 all in? :)
PM me your payment details if that's OK with you?
vr6south
Post by vr6south »
I'll take them if you can post them? Say £18 all in?
Just to confirm they are the ones which sit to the side of the head lights?
