skipster wrote:Just checked my oil level again (another top up required). 0.6/litre approx top up in 600 miles. So on that clearly 1/litre per 1000 miles. Slightly above VW tolerance but new rings still only 2,600 miles in. Won't go back just yet.
I do not want to discourage you, but 2.600miles are enough for ring to fit...
The only solution is engine replacement and fingers crossed: from our survey, about 50% of GTI are faulty and about 50% of engines replaced re-presenting the same problem. Very few the cases that piston rings replacements solved the problem...
BTW, after that one forum's user has succeeded on having back his money spent for his GTI (after rings replacements that didn't work), now in Italy there is a group action coordinated by the same attorney: all GTI's users who engine or rings replacements was unsuccesful, are trying to have their money back...
But you might be lucky and if you have your car from new and can help the process by not running the car in as VW recommend
I was less concerned as the new engine code was meant to come in May?, but i dont believe that if they are saying they still can't fix it in existing cars.
If the new engine code fixes it they would be able to replace knackered engines already out there with good new ones surely?
I agree it sounds like VW dont know what to do.
They will have to reply to me at some stage .... Will post here what they say.
Re the run in ... You are suggesting rag it out of the box?
Mine does already have replacement rings (have done 2,600 miles since they have been replaced). Whole car has just under 6,000. Oil consumption has improved for sure since the rings were replaced but it is still too heavy for my liking. VW told me that the running in period effectively restarts at zero once the rings are replaced (which yes, I can see their point). But I can't see the consumption reducing by much any time soon.
I still get the sooty deposits over the rear hatch and bit of oil smoke occasionally when pulling away.
Yes Skipster, that's what I mean, the oil consumption is still high also after rings replacements and from my point of view will not improve anymore: break in period for rings is already ended after 2.600 miles...
Stugolf1 wrote:At my wits end, if I want to reject the car I could loose £6,000 in less than a year becuase I put my own deposit on the car
Presumably you would lose £6k in depriciation anyway if you sold after 1 year? It's not a direct consequence of it burning oil that you would lose £6k is it? Therefore VW shouldn't really foot the depriciation bill.
I asked them to give me a working car, they apologised and couldn't, why should I keep a car that can't be repaired? And pay for the privilege each month
6K on the Polo is 12 months is far more than average too, the cars are known for the faults thus dropping like a stone in value
I had a new engine put in and I drove from the dealership after having if fitted to the closest link road and smashed the s**t out of it and have done as much as I've ever wanted and taken no pre cautions, result? An engine that has normal oil consumption
Yes but they haven't actually cost you £6k because of the oil issue. It would have depriciated at least £4k without it. If you haven't actually had the car and it has only been sat in a dealer awaiting being fixed for a year, then yes I'd agree you should get 100% of your money back. If you have used it inbetween trips to the dealer, then you should pay the depriciation for the amount you've used it.
