Today I went to do a brake down at work and thought it would be a good idea to take my car instead of the van because the roads where nice ..... I raced a vectra Sri. Then a Subaru ... Then a A4 ..... Then my car started making a horrible noise sounded like a tank but wasn't miss firing . So I got the rac out he looked but couldent see what was wrong waste of time he wouldn't tow it So I drove home and it sounds fu#ked . My friend says the turbo seals mite have blown or gasket from turbo to down pipe ..... Off to garage tomorrow for a check ...... If its knackered I hope to rebuild fingers crossed
Sent using tapatalk
A bit scared for my Gti's life
Re: A bit scared for my Gti's life
Hm, that sucks :/
Is it mapped? I'm not sure if it matters tho, just curious.
Lowthy1989
Check your manifold bolts! Common for these to come lose causes loss of power and makes it sound like s**t! Happened on mine twice. Luckily mine was just bolt them tighter job and this was about a year ago now!
- lukey GTI
yeah its mapped revo stage one , forge dv .. cone filter , decat exhaust system
ill check the bolts thanks
buzzmotorsport
Any warning lights up?... oil pressure ok?
Alex
Alex
- lukey GTI
Engine management is always on because of decat Getting it mapped out soon hopefully . Oils okay . Apparently my forge dv is faulty that's why it sounded so. Bad
Sent using tapatalk
Sent using tapatalk
buzzmotorsport
Check for a split in the hose that runs to the fb! Friends tt same happened! He got loads of turbo chatter and no power!
Just a thought!
Alex
Just a thought!
Alex
- lukey GTI
thanks alex i will do maybe i should change all my hoses for new ones plus it would smarten the bay up
This happened to mine, DV vacuum hose split, lost all turbo power and just got loads of turbo chatter rarther than the standard "ptshhhhh"buzzmotorsport wrote:Check for a split in the hose that runs to the fb! Friends tt same happened! He got loads of turbo chatter and no power!
Just a thought!
Alex
- lukey GTI
Think that was my problem. And the other noise was the plastic engine guard tray it was loose and flapping around
Sent using tapatalk
Sent using tapatalk
