how many positions ? :)
deadcat
Post by deadcat »
How many positions are on your ignition?
is it just the 1 then ignition or is it 2 (power,coil,ign)?
mines just the one.
GroovyCarrot
Sponsor
Post by GroovyCarrot »
Mine just has off - ignition - starter motor.. it feels like it has a notch for 'accessory', but it doesn't actually do anything, plus I can only find the notch sometimes, so I assume it's not meant to do anything :)
LogIK
Post by LogIK »
Stop - Ignition on - Start
Karl_CLCoupe
Post by Karl_CLCoupe »
IGN- Start.
I know, its a bit of a pain not having an ACC position for a radio. Especially if you forget to turn your radio off.
Thanks.
Karl.
Tahrey1043
Post by Tahrey1043 »
OFF - ON - STARTER
How many others do you need? :D
(i have my radio connected to the permanent power line, w00t..... i hate cars where you need the key in to run the stereo! just got to sort out a bypass switch to override the lights going off (with a buzzer, natch) too, for those night-time coasting moments :lol:)
never forget to turn the radio off tho - the polo's skin is thin enough that you can tell its still on when you're outside!
Gareth_GT_Hatch
Post by Gareth_GT_Hatch »
You can cheat and get round not having an accessory function. Its not great tho (will kill ur battery) Steve milo was showing ppl at inters. If u set ur lights to full on the switch, then pull back the stalk for main beam, then put ur wipers on occasional swipe, the rest of the electrics in the car will work (fan, ciggie lighter, radio etc.)
Tahrey1043
yeah, i found that out soon after i got the car..... wierd how that works, i wonder why! is it designed in, or just a short-circuit fault?
havent yet figured out what it's useful for though, apart from showing off "hey look at this wierd thing my car does", unless your key breaks in winter and you need to run the heater til the engine heat's gone....
hmmmm i wonder if it keeps the ignition working too! bit hard to hold both of those on and turn the key to OFF tho, would need a 3rd hand.
(alternately, put key in, undo steering lock, then roll down hill and try to bump start... there's still the little problem of needing an extra limb to steer with...)
retro
Maybe it's for the parking light?
Post by retro »
Instead of turning the lights on, try just leaving one indicator on when you turn the ignition off, and see if that works. If it does then I think it's probably just a side effect of the 'parking light' feature.
Tahrey1043
nah tis definately the full beam thing that works it (and the ignition is hardwired to the key it seems)... not sure wot your on about with the parking lights! they seem to work as a side circuit of the light switch itself..
retro
Post by retro »
It was just a thought.
The parking light is the only contact in the ignition switch that is connected when the ignition is set to 'off'. When you turn on a parking light, it feeds power through the ignition switch into the lighting circuit, instead of directly through the fusebox like the main headlamp switch.
If it had worked with just the parking light on, that would've meant less of a drain on your battery when you were using power without the engine running.
Tahrey1043
ah, gotcha. but "what" working with the parking light?
retro
Post by retro »
The pseudo accessory mode that Gareth_GT mentioned.
Tahrey1043
Ahhh... gotcha
SpikeyG40
Moderator
Post by SpikeyG40 »
just to add my point about the how many posistions, when the ignition is turned and all the lights on the dash come on, it also turns the fuel pump on! just enough to send some fuel ready for starting! :lol:
just wanted to add that!
schneil
Post by schneil »
Hello
I'm a newbie here!
Ummm just thought i'd add that my car radio will only come on if there's a key in the ignition.
so is the key in the ignition equivalent to the "acessory mode"??
Neil
