Guide to changing Engine temperature sensor on Polo MKV 6n2
Post Instructions on DIY modifications here - use all information with caution!
pberry
Re: Guide to changing Engine temperature sensor on Polo MKV 6n2
Post by pberry »
JTLondon wrote:is this guide applicable for a 98 R reg 6N?
alexperkins wrote:Its similar, but take the instructions with a pinch of salt as the engines have a different layout mate.
My 6N2 (Saloon) has the temp sensor on the bottom right of the engine. It can be hard to spot but essentially just follow the radiator hoses and where they enter the engine block is about where you want to look. The sensor plugs in at right-angles to the connection.
jonny6n2
Post by jonny6n2 »
also dont do it when the enigne is hot. i ended up with roasting coolant all over my hands :oops:
kingsleysaywell
Post by kingsleysaywell »
i have the problem as most people that my temp gauge on the dash goes to the bottom when im driving and then the middle when im stopped. whats the aprt i need and how much?
what is the orginal symptoms of this persons problem? like how did he know it was the temp sensor?
eyaaz6n2
Post by eyaaz6n2 »
Prabz wrote:Hi guys i think i have similar problem... What it is when started the car and driving the temperature will start to go up... but when driving for a little while it sits just under the half way line... then when driving for like 20 mins or so it drops right down to the bottom... Another thing is the needle doesn't go to the middle it sits just under it... Wondering if anyone could help me ?
Same problem did yoy manage to fix this
alexperkins
Site Admin
Post by alexperkins »
Change the green temp sensor. If that doesn't fix it, change the thermostat.
eyaaz6n2
Post by eyaaz6n2 »
Where does the green temp sensor be and how much are der also where can i get it from new to this
alexperkins
Site Admin
It goes in the thermostat housing as detailed in the start of this thread
Only get a genuine one from VW. About £25 give or take.
marcgoldhawk
Post by marcgoldhawk »
Hey guys, been having the same problem with my Polo (1.4 16v), and only noticed the isane fuel consumption when I took a 200km round trip out of town today. Anyone know the part number???
alexperkins
Site Admin
059919501A ensure you get a genuine VW sensor too!
marcgoldhawk
I have managed to find one for US$65, but they say it's a "Quality VW Part", and our only VW dealership say they no longer stock the part nor can they source a genuine one for me :x
alexperkins
Site Admin
Thats a crazy price.
Im surprised your local VW dealership says it cant get them considering this is one of the most widely used temperature sensors that VW have ever used - its used on loads of golfs polos boras etc!
marcgoldhawk
That's what i said to them!! but they tend to become very idle when a customer wants something specific.. I eventually got the part "Quality Part", which is a German brand called Vemo?? Anyways, will have a go at replacing it this afternoon..
alexperkins
Site Admin
Vemo appear to be good quality
Sounds like they need a kick up the backside lol!
mark.townsend
Post by mark.townsend »
Hello All,
New member here. Driving a 2001 1.4l Automatic. The 4-door Hatchback. Just had the Engine Management light come on while driving the other day and realised the temperature gauge on the dash wasn't reading. Car's still driving absolutely flawlessly, even in this cold snap so I'm assuming the engine temperature sensor's failed open and it's constantly reading cold. The needle does seem to lift slightly on occasion, but not by much and not for long.
Not really flush with cash at the moment so I'd like to take a swing at replacing the sensor myself, I'm just lacking the sensor itself and a clear idea of where it goes. The images at the beginning of this thread seem to have gone AWOL so has anyone else got photos/diagrams? Also, I'm trying to find the right sensor but the one mentioned earlier in the thread doesn't seem to be on EuroCarParts. The closest I can find is either Temperature Sensor or HAAS Temperature sensor.
Any thoughts?
alexperkins
Site Admin
Welcome.
I would say its probably the temperature sensor dead, plus the thermostat failing (its very common as the mornings get colder when they are worn)
The sensor lives on the right hand side of the engine in the coolant housing where the top radiator pipe goes into - the thermostat is in here too
As for buying the sensor, get a genuine one from VW as the ones from euro have a very short life span. Same goes for the thermostat. Youll want to get some more G13++/G14 coolant too to top it up as youll lose a fair bit.
